1 - 9 of 9 Posts
OK we put in a 302 in my 78 Ghia coupe. Runs great while going down the road...about 190-200 degrees, but when I'm idling for a few mins temp starts to go up. I changed the waterpump and thermo. Also I have headman headers on...was thinking about getting the hookers that have the coating...would that Make a difference? The rad is part 514 and 3 core using the mechanical fan. Not sure what kinda of aftermarket electric fan would fit or take care of the problem. Please help. This is not a stock 302...was just gonna put the reg manifolds back on if all else fails. Maybe I can find something at Carlisle this week end. I usually run my car in the parade on Memorial day and today it over heated and I had to retire to a safe spot early....any advice and help is greatful...thanks!!
YO STEVE
The headers would make a slight difference but what you really need is a better fan. I have a SPAL electric fan on my car and it workd great, never gets hot. You can get them through mustangs plus and they are pretty easy to mount.
if you dont have a shroud, your not getting good airflow. Add an electric or two, or find a shroud, and Im sure all your issues will be rectified.
as already been said if you havnt got a shroud already get one, it made a huge difference for me, my guage read 3/4 before putting on the shroud it read 1/4 on the guage after
and on a separate occasion a new radiator cap fixed my overheating problem, might want to try that, its cheap
I take it its a new motor? I fought a overheating issue for a few years (didnt drive the car much in the summer). Tried everything else, and it ended up..hate to admit it, but I had one head gasket on backwards. Now even in the 110 degree summer weather it runs cool.
Just a thought
Tracy
The engine is a 79 302 and was torn down and rebuilt. I'm gonna try getting a different rad cap and just look for another fan or electric fan in Carlisle this week end. Thanks for ur input guys!!
YoSteve
If I remember right, each pound of pressure on the radiator cap that you add will cool the engine temperature 7 degrees. If the timing is off, it will add to your heating problem as well.
A higher lb. cap will only keep the liquid from boiling as soon as it would with a lower lb. cap. The heating problem will still be there.
A proper shroud and fan is a huge deal when it comes to a stable cooling system.
The geometry of the fan and shroud should be set right also.
No more than 1/2" max clearance between the fan tips and shroud and the fan should be inside the shroud with between 1/4" to 1/2" of the blades hanging out of the shroud.
I got my $5.00 shroud from an 84 S10 Blazer with a V6. Fits well with a just little trimming around the hose areas.
Also the radiator needs to be very clean. My 500hp 408 runs at a steady 200 dg without the electric fan and 180-190 with the electric fan in 80+ dg weather.
The electric fan is a 1400 cfm pusher fan from Summit Racing mounted between the grill and radiator.
I changed the water pump pulley to a smaller one and it runs a lot cooler...turns out when we bult the engine we used a bigger pulley than called for...thanks everyone...
1 - 9 of 9 Posts
