21 - 24 of 24 Posts
don't feel bad I FEEL YOUR PAIN i have a 67 galaxy 460 doing the same thing I have seen this and heard this issue on 289 351c 429 460 545
my build is new also still getting hot 220 to 240 I am stumped as well...........
new aluminum heads
gaskets are on correctly I tore it down to check
fel-1231 intake gaskets scj
6al ignition
msd 3 step retard billit dist locked at 36
comp cam set straight up
true tdc at the piston
I have used a 160,180,190, blue rest and a gold
I used a northern 4 core a be cool 4 core now a frostbite down flow 4 core
I used a tarus 16" fan, I used two 12" haydens now I have perma cool 3500 x2 fans with matching shroud
open exhaust
fpa headers
roller rockers
bushed 9:8:1 pistons
dual fitech fuel injection afr set 12:5:1
8.8 wires
colder plugs
I used anti freeze and now on straight water with water wetter
I added a pusher fan it hurt more than it helped
it is boosted I went from 12 psi to 6 psi
I am ready to put a small block cheby next to it and scare it straight I am at a lose too and there are allot of peeps having the same issue the one who figures it out gets a cookie and 15 extra minutes at recess
new aluminum heads
6al ignition
open exhaust
fpa headers
roller rockers
8.8 wires
colder plugs
Have you tried running the car with out the hood on it?
You need to copy your content her to a new thread so people will respond with helpful comments.
21 - 24 of 24 Posts
