try this, raise the front of your car as high as you can so the radiator top is higher that the heads. fill the radiator then place the cap on before yoou lower the car. You also must have a coolant recovery tank so that no air can get into the system. I have used this method several times over the years and it has worked for me. Let me know what happens....T
