With a bunch of work needing done, I decided to break down and buy a real life $99 parts washer from Tractor Supply. It's the generic Chinese unit sold by Harbor Freight, and tons of other outlets. While there, I went ahead and bought a couple 5 gallon cans of their PSC 1000 solvent. Great stuff, as it works, and hardly has any odor! This is NOT the water based crap. I also added in a quart or two of Automatic Transmission Fluid to keep it from drying my hands and hopefully help minimize any surface rust. Hey, ATF is pretty good cleaner in it's own right...
Anyway, I got it home, noticed that the metal hose was screwed into a PLASTIC fitting! Yea, a metal hose you bend around to make it spray where you want! They must KNOW it's a bad idea, as they even include a spare fitting with the unit! LOL
Well, it worked great! ...for about a week. After a week, the pump quit working. I also noticed a bunch of dirt from parts floating around in the solvent. Instead of buying another CRAPPY pump, I decided it was time to UPGRADE.
I shopped around for a GOOD pump that wasn't too expensive, and decided to ad a FILTER to keep the solvent cleaner!
Here is the old pump. It's puny, extremely lightweight, and has a plastic fitting the metal wand attaches to!
Here is the new pump. The image on the Ebay ad does not show the cage on the front, but it comes with it. $64 and free shipping.
Here's the unit all put together with the filter and METAL mounting that is bolted down for the wand. The filter makes a HUGE difference in how clear the solvent stays! HIGHLY recommended upgrade for anyone with a parts washer! The stronger pump has NO PROBLEM pumping through the filter, and sprays solvent with plenty of force. Pump is significantly larger than the stock one, and about 5X as heavy. lol I also purchased a parts washing brush with a hose that fits over the metal spray wand. It seals over the wand with what looks like a spark plug boot. It's a really nice, stiff brush and does a great job with the solvent spraying out of it. I believe the brush was around $20. The remote oil filter mount was $20, and takes a SBF oil filter! All of the fittings were sourced locally.
The Pump is Before the Filter. It's intake at pump - to Filter - out nozzle- So technically the debris still get's to go into the pump, but it doesn't get pushed back into the tank, thus removing about 80% of all the sediment from my point of view..
The pump is made to be able to pass anything that will go through the screen. Small debris will not hurt it. After the pump, the solvent goes to the filter... then through the hose to the outlet. Solvent stays FAR cleaner than without a filter! You also don't get any grit and debris left on your parts.
Awesome! Thanks for the answers. I'm definitely going to do this with mine. One more question though, what kind of rubber line did you use?
I would think rubber transmission cooler line would work well and would maybe be less likely to break down from the solvent over time? How right/wrong am I on assuming that?
Hey friends,
This is Mario Goldstein and I've spent years as an auto mechanic, making a decent living.
About five years ago, I realized that the real money was in spray painting and auto body work. I took a cut in pay at first, just to learn the skill. Since then, I've never looked back.
Today...
Hello everyone...
I figured this was as good a place as any to make my first post. I own a 1967 Fastback that I inhereted from my father that he purchased in 1994. It isn't an all original car by any means but it's all there but the time has come to do something with it or there won't be...
ALLRIGHT lets see what's out there... anything you have ever owned, or drove for a while... like your folks car or lovers.... hmm
year..make..model & extended info..Action..sequence
1967.. ford.. mustang fastback..Still own..1
1987.. dodge.. dakota..blew up..2...
Does anyone remember the slicks that were sold in the 70's or 80's that had the humorous text on the side walls?
Torque Twisten, Tire Smoken, Axle Bustin etc.
If I could get a picture, that would make a great avatar.
Hello,
I'm looking for a little help please.
I have searched the web to find the decals for this car & the only ones I could find are the smaller Cobra's for the trunk lid. I'd like to get the set for the sides. The car is my Brother-in-law's. He want's me to make him the decals but I don't want...
