Taking a weekend to transform to BBF power from a light SBF is always fun. As the Paxton was used on factory SBFs many years ago (T-Birds and Mustangs) and improved since then, it's a solid and reliable system. I would check with Paxton for a hat height from mount base to wing nut (not just overall), and a height (relative to a fixed point - like the deck or distributor boss) of the supercharger. With these, you can verify it will fit without a rude awakening $2500 into the project that you need a funky hood or $pecial bracket$. Also, the listed 'suggested' accessories are a good idea to consider, but most are either not required, or at the 'race' level as some are listed.
Friend of mine put one on his 67 Mustang last summer. He had to install a shorter intake manifold, the RPM AirGap caused the air box to just hit the hood. Other than that it was pretty straight forward. Lots of tire smoke..
