You MUST check the coil resistance, as explained in the instructions. Use a ballast resistor if your coil has 2 little resistance.Otherwise, you'll pop the unit. But, why not use a dura spark? the're cheap, U can get parts anywhere and, when used with a MSD or other unit will fire anything. Just a thought.
