21 - 31 of 31 Posts
Lookin' good! Are you going to put add a cross over pipe in the exhaust. Nice and easy to do while you're there.
Discussion Starter #27
HP & Torque: 422 HP / 480 FT LBS
Compression Ratio: 9.7:1
Aluminum Heads
Hypereutectic Pistons
Roller Cam
Cast Steel Crank
Block:
351 Windsor blocks bored .040 over
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Rotating Assembly:
New cast steel crankshaft
New I-beam rods
Hypereutectic pistons
Hastings Moly rings
Rotating assembly balanced to within 2 grams
Melling high volume oil pump
Hydraulic roller camshaft
Cloyes double roller timing chain
Camshaft degreed for maximum horsepower
Cylinder Heads:
BluePrint Performance Aluminum
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
Cam Specs:
Roller
.543 Intake / .554 Exhaust
218 Intake / 226 Exhaust duration
@ .050 - 112 degree lobe separation
Ignition Timing:
34 degrees total at 3500 RPM
Discussion Starter #29
Ready to pull my hair out , I've been to half a dozen wrecking yards trying to find an alternator and power steering brackets that will work on my 351w. I orderd a T-Bracket from James Duff (Bronco Parts) for the alternator, the power steering bracket will work if I drill new holes and fill in the original holes
This build is starting to Really get on my nerves
But in the end it will be worth it and being able to say I've done everything and not paid for a Hot Rod
Sorry for the rant
Peace out
21 - 31 of 31 Posts
