You've got a '74 case fill. The other one is a '75 pan fill. Internals are the same. Only the case and bell are different. The one you have is right for a 5 bolt bell. Just be aware that the input shaft is 26 spline. Original 5 bolt C4s had 24 splines. Not a problem if you have the right converter.
