If it's a roller motor you can make a solid lifter. Remove the circlip on one of your lifter, pull the little piston out remove the spring and flip the piston over. Put the little circlip back on the lifter. After your done reverse the process. Use a drill press to push the piston down far enough to get the clip out. Works great!!
Regards,
BillGear
www.289mustang.com
