Ok, i bought a T5 tranny from this guy, useing the ID chart on this website. It is a 86.5-89 V8 tranny, according to the tag on the bolt. But i just ran the #'s off of the caseing (at 5speeds.com), they are
13-52-066-919
13-52-065-908
13-52-097-913
it shows that 2 of these numbers go to a 1984 mustang/capri 5 liter. I have one bum t5 that is out of a 1984 5.0 allready, with an 8 bolt bellhouseing, this one is a 6 so thats good at least. But should i still use it, is it really a 86.5-89 year, (which i have no idae why they used the case) or is it just another junk 1984, with a good tag(like someone switched them)? the guy gave me a 2 week return on it, so i need to know quick to return it or not, THANK YOU
Discussion Starter · #2 ·
does anybody have anything for me?
Its possible that someone could have replaced the tag, however It could be one of the earliest of the 86.5-89 that ford used the leftover casings when building. the casings are the same i would think.
Check the bearing visible from the front in the case. It should be a Timken brand, showing that it is indeed an 86 and newer. (World Class) Check the casting mark in the top cover, which should say 86 (or higher) inside of a double lined circle.
