alright, just got an old points distributor and coil to get my motor running, I need to know how exactly to wire this up, im not real sure about this, Ive got my 3 wires from the coil, ones my primary that goes to the distributor and the other two i need to know what to do with? just gotta get this wired, run fuel lines and install my starter and my two year project will make some noise.
Not sure what vehicle your working on but all of my points distributor cars only had two wires from the coil.One going to the distributor from the negative side of the coil and the red with blue stripe wire that comes from the ignition and goes on the positive side of the coil.Is it possible the other wire is for a tach?If so it should go on the negative side of the coil.
