Selling complete Ford 351W top end 9.5 deck. The heads are AFR 205's ported by Ram Racing in Oxford PA. The heads flow
Lift int exh
.200 157 113
.300 224 171
.400 269 217
.500 295 236
.600 308 243
.700 312 249
They were flowed using a 4.060 bore & 1.750 pipe. Chamber is 58cc's. The valve springs are Comp Cams 26115 with Titamium retainers & keepers. The intake is a World Products/CHI port matched to the heads. Also included are a set of Scorpion roller rockers & Comp Cams push rods & ARP head studs. I will also throw in a set of Ross pistons 4.125 bore for a 4 inch stroke with a 6.250 rod 14:1 compression with these heads and a set of Ford motorsports valve covers. There are only 12 passes on the heads since they were done. All you have to do is bolt on & go. Asking $2600 obo
Lift int exh
.200 157 113
.300 224 171
.400 269 217
.500 295 236
.600 308 243
.700 312 249
