1 - 14 of 14 Posts
Does anyone know if you can grind the threaded lump out of the exhaust port, and how much can the head be ported before you run into problems. thanks jjc
The thermactor bump as it's called, is totally removeable. As for your second question, do a google search on porting E7TE heads, or stock 302 heads, and you should find a great walkthrough that's been floating around forever. Matter of fact, give me a bit and I'll take a look through my 10 million favorites and see if I can't find it =p.
Cris
On 2006-09-29 21:58, Is1BadFord wrote:As for your second question, do a google search on porting E7TE heads, or stock 302 heads, and you should find a great walkthrough that's been floating around forever. Matter of fact, give me a bit and I'll take a look through my 10 million favorites and see if I can't find it.Cris
Chris, did you find that link?
On 2006-11-07 11:17, 393Clevor wrote:
Goggle = porting e7 heads
http://www.armstrong.edu/ron/auto/e7.html
Something in this article made me wonder how the DOOEs I ported compared. The E7 article says that the width at the pushrod bulge ends up about 0.9". I measured my DOOEs yesterday and they measured about 1.020 at the bulge. Either I ported the begezus out of those heads and the E7 port job was conservative or DOOEs have a lot more room for porting. I did take the wall thickness at the pushrod bulge down to less than 1/16 thick.
I de-thermactored my 69 truck heads and messed with the bowls also. Did it with a dremel and some grinding bits. Turned out nice but did take some time.
[/quote]
[/quote]
This is something that most people never realize, or at least never gets mentioned.--- The early windsor heads have a considerably smaller push rod hole. It leaves potentual for more cross section.
Hi dears... this is my first post here... can you explain me what the best heads in the market, in exception aluminum ones, that I can install on my 302W ????
1 - 14 of 14 Posts
