1481 - 1500 of 1541 Posts
Suspension:
Ridetech Coilovers with their 4 link setup in the rear
Fatman Fabrication front control arm w/ crank bolt eliminators
Borgeson Steering box w/ custom column and spherical bearing tie-rod ends
Brakes
Wilwood master-cylinder and prop valve
Front: Wilwood 13 inch rotors with 6 piston claipers
Rear: Wilwood 12 inch rotors with 4 piston calipers
Rear Differential:
Strange Nodular Pro series 3rd member with 3.70:1 gears
Strange 35 spline axels
Strange S-Trac Diff
Wheels:
17x8 and 17x10.5 Weld RTS 71 wheels
Engine:
Scat Forged 4.3 stroke crank
Scat H Beam rods w/ARP 2000 bolts
CP forged Pistons
DSS main cap Girdle with ARP studs
Kaase Oil Pump
Comp 304BR-8 cam w/solid roller lifters
Comp Ultra Pro Magnum Roller rockers with stud girdle
Kaase P-51 Heads
TrickFLow Mafia intake gasket matched to the P-51 heads
Canton 8 quart trap door oil pan
Holley Sniper 4500 EFI w/ Hyperspark Ignition.
Trans:
C6 w/ billet servos and 4R100 planetary gears and additonal clutch pack
10 inch 3000 stall converter.
My 1963 Galaxie 500. Has a 460 with a “Police” cam and a C6. Sat in a garage for 25 years. Picked it up on eBay for $1500 ! Almost no rust and the interior is nearly mint. I got her running to make sure that she would, then I took the top of the engine apart. I Put an Edelbrock manifold on with a Holley 700 that I rebuilt. Also installed an HEI dizzy, a 1 wire alternator, an electric water pump, electric fans, MSD box and a Hurst line lock. I painted the engine compartment and the engine. I put 31” tall Firestone gum dipped pie crust white wall cheater slicks on because everyone said they wouldn’t fit. I still have yet to install the 3.73 posi center section I’ve been saving plus I have to wire everything in the engine compartment. Been working on it for a year now. She’s almost ready.
164483
Some gorgeous Galaxies in here. @Enzod...I love the stance on that sedan for some reason. It looks baaaaad (in a good way)!!
