Little help. How do you get the power steering belt on? I don't see a tensioner or a pivot slot, just 2 mounting bolts. It is a 1963 Galaxie with a 390 and AC. A pic would really help too. Thank you!
This from a 1965 390
Here's a diagram from the 1963 Ford Electrical Assembly Manual (Jim Osborn Reproductions) - page 101 - for 352 and 390 engines with power steering and air conditioning. It looks like there's an adjustment capability provided on the 5751351 bracket located under the compressor mount bracket. Hope this helps. Good luck.
63 convertable
there is a different setup if you have the remote ps resivoir. but both have an adjustment slot.
Here's a diagram from the 1963 Ford Electrical Assembly Manual (Jim Osborn Reproductions) - page 101 - for 352 and 390 engines with power steering and air conditioning. It looks like there's an adjustment capability provided on the 5751351 bracket located under the compressor mount bracket. Hope this helps. Good luck. View attachment 169073
Fantastic! Do you know anywhere that sells the bracket?
