Has anyone had success with products that are designed to seal power steering leaks?
My Galaxie has a heck of a leak. I haven't been under the car yet to look at where the leak is coming from. I'm just doing some info gathering right now.
Thnx.
I've had a good experience with the Lucas Power Steering Stop Leak. I probably ended up using a lot more than the recommended amount, initially, but I don't have any dripping anymore. Now, if I need to add any fluid in the spring, I'll just use Type F ATF. For the last 10 years I have not felt the need to delve into rebuilding my steering gear.(y)
