Ford power steering is working just fine but it leaks. I cleaned it up and figured out where, it is from under one of the bolts on top (that holds the sector shaft cover down?). Since this is my only complaint I am against buying a whole new box. I could go for a kit, like More Information for GATES 351220 although even that might be in excess of what I need. I have the FSM and it looks like I need some special tools. Hopefully the kit has better instructions than the manual. Has anyone made a repair like this and can tell me what is involved?
Loosen the bolt then tighten it back down. If that doesn't work, then add a little sealant, or a sealing washer.
