Original plan was to use Fox body pump, but ran into mounting and alignment issues, so easiest solution was to use original pump with fabricated hose.I'm probably not much help here, as I can't find my GPM reference. But IIRC, the Borgeson-Saginaw was 1.8GPM, but there's more than one version out there. Oddly, I thought the Fox used the CII-style pump, which IIRC (again) was around 1.5GPM?Hopefully others will jump in here, but have you considered adapting/spacing a Fox pump and mount with the V-pulley?
BTW - stock is also IFS.How's the turn radius and bump-steer?
