1 - 11 of 11 Posts
Does anyone know how much a Powerstroke engine weighs? I have been mulling around doing a conversion into my '67 F250 and was wondering how heavy one is.
Some one here might be able to answer that for you....in one of the forums
http://www.ford-diesel.com
the kicker on trying to install a PSD is the engine is all computer controlled. There is no mechanical connection between the accelerator peddle and the engine, the speedo is picked up from a sensor mounted inside the rear axle housing, etc. You would need a donor vehicle to get the wiring and computer and etc.
I am aware of the difficulties but I am absolutely fearless and am confident I can overcome these problems.
May i ask how old you are? I have tackled a lot of things in my life, I am 51, but I don't think this is one I would want to tackle without a lot of help and spare parts handy. And I own a PSD .
With accessories added it weighs close to 1100 lbs. It's a heavy mutha. Take the alt, ps pump, ac off and it's right at 1000 lbs.
Later,
David Cole
69 Mustang Fadstback Drag Car
'01 F-350 Powerstroke dually.
I am 44 I have done many swaps and I am employed as a Maintenance Electronics tech at Boeing Airplane CO and am accustomed to working on multi-million dollar robotic and CNC machines and I think I can do this. Besides, nothing ventured, nothing gained!
Make sure you get a chip and leave room for the PROPANE tank. With these two mods you're looking at about 350hp and 800lbs/ft at the REAR WHEELS !!!
That would be Smokin' in a 67 Ford.
Horsepower TV did a buildup on a new Dodge Cummins 24 valve inline 6 diesel.
Stock, it made 196hp on their Dynojet.
A chip added 39hp
A 4" mandrel exhaust added 4 more hp.
Propane, larger injectors, and an exhaust temp sensor tied into the computer brought rear wheel power up to 428!
I believe they said all the mods cost around $4000.
Here's the link to the company that makes all the parts. They make them for Ford as well. (Bully Dog)
http://www.bullydog.com/
Good Luck!
Ummm, Chilly, arnt all diesels injected??
1 - 11 of 11 Posts
