I'm building this engine for my 68 fairlane. Pictures shortly ....
I just got the Block back from R&R performance in spring lake park mn.
they suck ballz and I will never go back there again ...long story ..
Block Mirror 105 block
Bored 30 over with torque plates
line honed
decked for zero
frost plugs and cam berings installed
oil mods done , added thread in plugs
cost $800 they included arp bolts witch he needed for the line hone
I got the block and cleaned up the casting flash and rewashed the block and painted it duplicolor gloss black
Crank is a scat 4.125 fully ballance
rod's are scat I beam 6.700 chevy rods.
pistons are mahle 10.8:1 coated flat tops
arp bolts to keep her together
Bearings are all king racing bearings
Camshaft is a comp cam's solid fb-294s-10 294/294, Lift .605/.605
lifters that came with kit
oil pan is a mildon 7qt pan with the required pickup
oil pump is a hv57 melling and a aftermarket pump rod
timming chain a double roller from Milodon 15007
heads are 60069 edelbrock rpm series
intake is a edelbrock rpm intake
carb is a 750 holley vacume
line honed
decked for zero
