I just put a 331 shortblock from DSS in my 1993 LX. I also install the Trickflow TFS-K514-350-370 up engine kit. I put 24lb injectors and a Pro M MAF sensor (75mm). It has a 70mm Throttle body and EGR Plate from Professional Products. My question is, do you have to swap any of the wires going to the Sensor with the Pro M. I have heard that on sensors like BBK, you have to swap 2 of the wires.
The reason I am asking, is it is loading up pretty badly....also, when I accellerate rapidly, I get poping in the intake.....
I have checked the timing and it is right on the money....it is set at 12 degrees advanced with the chip to the distributor unplugged....
Any suggestions...
Frank
<font size=-1>[ This Message was edited by: fjackson on 3/14/06 3:47am ]</font>
Any suggestions...
Frank
