Hi guys,
I have a problem with the 2-3 upshift and 4-3 downshift in the T-10 in my sprint. When I make the 2-3 upshift it goes in kinda hard, and it won't downshift directly from 4th to third unless I'm going real slow or go from 4th to 2nd to 3rd. I'm guessing syncronizer. Would an additive help? Thanks!
no you might check your shifter adj. if one has pressure if will be hard but more than likly trans. is worn dont exspect to just do syncros its always more
Thanks blown 33, I really want a mildly worked C-4 anyway, so I'll just baby it until I can afford the swap.
