1 - 20 of 30 Posts
Have been drilling and installing the aluminum parts for the last 2 weeks or so, along with fitting the front spindles, aframes, shocks etc.
Engine is due in next week along with the rear axles, diff, and transmission.
<font size=-1>[ This Message was edited by: psivory on 8/28/06 1:38pm ]</font>
<font size=-1>[ This Message was edited by: psivory on 10/18/06 9:16am ]</font>
<font size=-1>[ This Message was edited by: psivory on 10/28/06 4:49am ]</font>
<font size=-1>[ This Message was edited by: psivory on 11/17/06 8:43am ]</font>
Hi
I am at a similar stage as you on my Cobra replica build. Rear Jag' running gear fully installed & am hoping to have my 84' 393 Windsor stroker installed later on this year!
Good luck from across the pond with your build!
Martyn
On 2006-08-28 11:32, martynUK wrote:
Hi
Martyn
Good luck with yours as well!! We are going with a new 8.8 rear end, 3.77 gears and a 302 roller cam crate engine. The trans is going to be race version T5.
On 2006-08-28 14:43, 65460 wrote:
Gee Scott, I just always pictured you a little older and taller too
You look as you feel Chuck..
Congrats Scott! (And family!)
Discussion Starter · #8 ·
Today we got the front brakes completely assembled and installed, along with the steering system, and pedal box assy with pedals installed.
Good progress so far. Rear is almost done as well, just need to install and we will have a rolling chassis.
Discussion Starter · #14 ·
We are thinking silver body with a black stripe.
Don't want to go blue with white stripe as there are alot of them around here. I haven't seen a silver one in the area yet, and we are trying to be different.
<font size=-1>[ This Message was edited by: psivory on 10/5/06 8:34am ]</font>
This is ironic I am completeing a older version from classic roadster It is painted Mercedes silver with Black stripe a351 alum bock taken out to 427 cu in with the Mass flo system we built a alum fuel cell put coil overs on it I live in ILL so plans are to be completed in time for spring weather. I will submit pictures when I can find a digital camera
Discussion Starter · #16 ·
Cool! We are also shooting for a spring completion. Going with a 302 roller block.
Discussion Starter · #17 ·
The rear end and diff were supposed to be BO till November, but this morning we got a nice surprise!!!
Things are moving along pretty quickly now!
Wheres the pic of the rear!
Discussion Starter · #20 ·
Here's the rear end:
Front End:
And the Money Shots:
<font size=-1>[ This Message was edited by: psivory on 10/18/06 8:13am ]</font>
1 - 20 of 30 Posts
