1 - 9 of 9 Posts
I have the FEL-PRO regular engine rebuild kit. Is this OK or should I step up to a "better" gasket. 429 with Edelbrock heads around 10:0 compression.Just need to know from someones experience. Thanks alot!!!
I am running "Dart" aluminum heads on my 350 SBC in Queenie's 67 Camaro.
I don't remember the exact part number of the gaskets ... but I do remember this.
Dart had a very specific recommendation as to what gasket to use ...
You might want to talk to "Edelbrock" and see what they say.
Larry Madsen
Las Vegas Nevada
<font size=-1>[ This Message was edited by: monstermach on 6/30/03 8:50am ]</font>
Edelbrock only recommends one brand of cylinder head gasket for their Ford heads, regardless of engine.
Fel-Pro.
I'm running ROL head gaskets on my 331 with AFR heads.
I get my FelPro's from Ford Racing...you can get two for about the smae price you get one from Summit or JEgs....
I would still revert back to my earlier post ... To simply say "FelPro" doesn't really answer the specific question.
Keep in mind "FelPro" is a brand ... FelPro makes a multitude of different head gaskets for the same engine ... this thread alone referes to two different specific part numbers.
Ask Edelbrock which specific part number of gasket they recommend for the heads you have.
Larry Madsen
Las Vegas Nevada
<font size=-1>[ This Message was edited by: monstermach on 6/30/03 10:04pm ]</font>
I guess I'll refer back to my original answer and be a little more specific.
Edelbrock recommends the Fel-Pro #1018 for cylinder head part # 60669 & # 60679. Assuming one of those part #s is the heads you have.
If not, just check the Edelbrock website for the gasket they recommend for what ever heads you have.
<font size=-1>[ This Message was edited by: mstngjoe on 6/30/03 11:24pm ]</font>
1 - 9 of 9 Posts
