I purchased a 1966 Galaxie 500XL convertible. The brake system has been worked on, power booster and master cylinder in the trunk (booster in pieces) all brake lines removed wheel cylinder kits in car. I am looking to put it back together. Where would the proportioning valve be located? I can't find one in the box of parts and haven't found it attached anywhere. Where is it supposed to be? Any ideas how I can get a replacement?
Jeff
if its a 4 wheel drum brakes..
there will not be any proportioning valve in your pile of parts..
as its only used for disc/drum or disc/disc application....
and if you have front disc prop valve would be positioned nearby master cylinder ...
Four wheel drums didn't have a proportioning valve.
