Another problem besides the reverse rotation water pump is that the 68 302 has a 3 bolt pulley on the crank and all the serpentine crank pulleys have four.You can change to a 69 or newer pulley but then your timing marks on the damper will be on the wrong side.One other problem is the reverse rotation water pump will have the rad hose coming out on the wrong side.If you go ahead and change all of these things you will still need a spacer on your 69 four bolt pulley to get the pulley's lined up right.Don't use the balancer off of a 5 liter because its balanced differently. There are ways to get around all of these problems but its not as easy as it first looks.
