Does anyone know in what order the 4 metal sealing rings go on the pump shaft of a 68 C4 Transmission. (1964-1969 sealing ring kit)
3 of them seem to be the same size (marked with green mark)
1 is smaller (marked with green and red mark)
None of my manuals specify.
Should be 2 of each size.The slightly larger ones go near the pump.Check them in each drum where they run first will tell you..
