Subscriber
Hey guys if you upgrade to a daytona pinion support, do you have to swap the yoke too?
Thanks, Tom
No, I don't believe so. I have two of them and the only difference is in the rear bearing (it's bigger.) The forward bearing and seal are the same as the standard bearing pinion support.
Whilst you don't "have" to change the yoke, the standard type "long" yoke will not fully thred on to the pinion threads...meaning the locking part of the nut isn't working properly.
The daytona supports use a "short" yoke from factory.
(Sorry R code but did a swap recently so its fresh in my mind)
On 2006-08-22 20:30, doctorj928 wrote:
dont they use a sold bushing instead of a crush sleve
jeff
Yes they do.
