a friend of mine has a 350 with an edelbrock torker II series cam with 292/300 advertised duration, the thing is his idle is not as rough as i thought it would be with that duration i thought the bigger the duration the more rough your idle will be, i dont know if im right, 292/300 advertised duration should be enough to give a rough idle, does lift play a role in idle roughness please help me out thanks a lot
