I was reading the article here at FordMuscle and they say to grind down the valve guide boss on the exhaust side.
I'm kinda nervous about doing that. Just want to make sure one last time, is it OK to grind down the boss?
Yes, it's OK to remove the guide on the small block heads. There isn't that much to get rid of anyway. You shouldn't have to worry about losing valve stability.
