Since your setup is very similar to mine, I wanted to ask you about cooling. What are you using in the way of radiator, fan, shroud, thermostat, and water pump? Did you have any problems with cooling or did it just work as is?
I got caught in traffic yesterday due to an accident and had to let it idle for about 10 minutes in stop-and-go traffic. By the time I got moving again, it was running about 215 degrees. I'd like to base any changes I make on a proven combination.
Thanks!
Thanks!
