Almost finished installing my new volt, oil pressure, and water temp gauges today. Cold start oil pressure read 60. Still need to install coolant temperature sensing bulb into my tri power manifold. Question is ---- the bulb is over 1 & 1/2 inches long. Does the tri power manifold water temp port have enough depth to accept a 1 & 5/8 inch temperature sensing bulb without bottoming out ???? If not I would need to plumb it somehow into the heater hose port. Thanks guys, I want to get it done early in the morning tomorrow.
