I found a 38-amp Nippondenso alternator that I think I will try to use on the Maverick. Only problem is, I cant seem to find a crank pulley that's small enough. I've got a factory crank pulley (7" dia), but at 7000 engine rpm, the alternator would be spinning I dont know how many million rpm--probably way too fast. Any suggestions?
Any number of aftermarket suppliers make crank pulleys. Divide the pulley diameters to figure the ratio, try not to spin the alternator much over 15,000 RPM.
Already tried. It's a 15mm shaft, whereas most aftermarket pulleys are 5/8" or 3/4" dia. I think I can "rig" a John Deere mower deck pulley to the crankshaft, using my buddies crank grinder to machine it to fit.
Moroso makes a nice crank pulley that is substantially smaller than stock. I just put one on my car and it seems to have helped keep the belt on quite substantially. Mine used to pitch the belt all the time. I guess 8k with stock pulleys was a little more than the belt could handle.
