Hi Guys
well our 302 is putting out 380 HP in a 3500 lbs comet with a 4 spd. trans.6.00 rear end gears 29.5 x12.00 x15 slicks our top loader has a 279 1st gear we what to go to a Jerico 4 spd. what gear ratio in the trans would you recommend also in the rear end we run most of the time at 6000' turn around 7000 to 7500 rpm the motor will go to 8000 + rpm and still pull hard. what are you suggestion. we only drag race
