Guys,
Took my car out to hanger to install aluminum radiator and auxillery transmission cooler. I let it set for about an hour and drained the antifreeze out of car. I loosened the original fittings from the transmission expecting to see transmission fluid go everywhere. There was not a drop of transmission fluid that leaked anywhere. Not one drop.I couldn't get any out of the radiator or the lines either. I've put about 3000 miles on this setup with the Jay Broader C6 and had no problems. The transmission stick says it's full.
Shouldn't I have seen oil someplace or does it drain back into the transmission when it's shut off. I'd have thought I'd have seen something. Everything works OK though. Jim
