Looking for advice on radiator cooling system upgrade after an engine swap. 1967 mustang convertable I6 to 302 v8 fuel injection c4 Aod. Not sure what I have to do to accommodate my swap.
You are sort of in the wrong forums with both posts....tech exchange is generally for something you did, and are showing others.
I would post these questions in the All Ford forum. In the end though, nothing fancy, need a V-8 radiator with outlets on the correct side, make sure the belt system you use turns the water pump the right way, and just a good 3 core radiator with AT fittings or an external cooler
Thanks for your guidance. I appreciate it. This is a great forum. I'll become more familiar with the format.
