I have a 68 302 2bl with 113k. I`m trying to figure out if this is a fuel problem or electrical problem. After I start my car and it warms up, I can take it for miles and miles on the highway but once I get off the highway at about 30 mins into city driving at a random light the car would shut off. When I start it, it will start right back up (always starts back up) and keep on going, sometimes it`ll stall again when I stop other times it wont. Occasionally when I drive I do see the belts dummy light flashing on the cluster. This is what I have changed in the engine (everything else should be presumed original from 68):
new Block to ground cable to battery
new positive cable to battery
new starter solenoid
new mech. fuel pump
new alternator (charges between 13.1 to 14.1 when driving)/battery/voltage regulator
New spark plugs, distributor cap, plug wires, air cleaner
new water pump/radiator/tstat/hoses
-With that being said I have not changed the frame to starter solenoid ground and my carb has a tiny leak at the base of the carb ( I would say about 3 ounces of gas a month). The carb seems to be working fine besides that and before it stalls there is no rough idle. Any ideas? something that acts up when its warmed up perhaps?
new mech. fuel pump
