so I'm looking to replace the rear brakes on my 65. do I need to remove the axles to get the drums off? if so how do I go about that? Stumped
Yeah what has happened is the shoes may have cut into the drums a little, beginning 1/4" from the lip. So now you can't pull the the lip over the shoes. I would suggest a flashlight, a thin blade screwdriver (to push back the check lever off the teeth of the adjusting screw), some spray bolt loosener like WD-40 or PB Blaster, and spend the $5 for a tool to turn the adjusting screw, which is pretty hard to do.
You spray the PB Blaster on the adjuster. Then hold the flashlight in one hand, push the lever in with the other hand and turn the screw downwards with the other. After a long time I got one side backed off pretty good, sprayed PB blaster on the hub and studs (which were sort of rusted to the drum), hammered with a BFH in between the studs and gradually wriggled the drum off. On the other side I gave up, put a chisel up against the adjusting screw/check lever and just busted it out. Then PB blaster, etc. I attached a pic so you can see the lever. It is on the backside of the wheel and prevents it from turning backwards, so you have to slide a screwdriver through the hole and past the adjuster to get at it.
Of course you might not have the lip problem and just some PB Blaster and BFH will do the job, I hope so!
