Unbolted the rear LCA and as I pulled out the bolt.. oops the rear end swung away and now the control arm won't reach the bracket (pic). Any recommendations?
Next pic shows the teensy crack that gives access to the nut inside the frame on the front of the arm. Realistically I think I will have to pull the e-brake cable through to make room for the wrench. Is that necessary? I don't want to make more trouble for myself!
This is not an emergency situation but winter is coming...
