hi im putting in some new leafs, the front bushings are rubber, the rear are poly, will i get bad results from the mix or deflection from the rubber one in the front or the rear springs?
No you wont get bad results, should handle fine. Better if you had poly front but that should be ok.
Rick
You didn't say what car, but if all 60's Ford leaf springs use the same bushings (and I think they do) I have a set I would sell cheap. I put a full set of poly bushings on my car and then put Cal-Tracs on it a month later. The Cal-Tracs use aluminum bushings so I removed the poly front bushings. I think they are in my garage, sealed in a plastic bag. If interested I can look for them a post a pic.
Later,
David Cole
