The reason they rub, is because the 93 Cobra has rear disc brakes and the axles are wider. So the GT wheel requires a little less backspacing.
Don't use washers!! You can get wheel spacers which are made of aluminum. You can get them to match you lug pattern. Their available in 1/8" all the way up to 1/2" thick spacing. Their available in Jegs catalog. I had to use a 3/16" set on the front of a 95Gt I had. I was using 5" wide Weld Draglites. They came with the wheels though. This was before they came out with the XP series designed for the 94up Mustangs. I never had any problems though. You probably wouldn't want to use more than a quarter of an inch spacer on the back though. Anymore, could put too much stress on the studs. You might be better off getting different wheels.
Ron Meyer
67 Mustang coupe (289,Windsor jr heads,4spd,3.55 posi rear)
86 Mustang SVO (Turbo 4cyl., 5spd)
79 F150 4x4 (Soon To Be FE Powered)
<font size=-1>[ This Message was edited by: RonMeyer on 1/25/02 4:27am ]</font>
