Hey guys. I know you all have probably hashed this over but I didnt find too much in my search on the topic.
I have a 63 and Im just trying to figure a wheel tire combo to stuff some fatter tires under the rear. I have been looking at a set of 15X8 rims that have a 5.5 inch backspacing. this might work well as the rearend doesnt appear to be too well centered in the wells. Anyway just wondering what/wheel tire combo some of you guys have used. I have to online order the rims so I wanna get it right the first time...thanks!!!
Hey thanks. Man that looks great...what a sweet ride! So with those tires on a 4" backspace, Im assuming your slight rubbing was on the outside?
How much room is there on the inner side? Thanks again!
Chris
I have 275/60/15 on my 64. I currently have a custom wheel with a serious backspace. Fits well, but you have to drop the shocks to take the wheels off. 15x5 in the front with a 185/65/15, I used to run a real skinny front, but they felt a little loose for me.
Karguy1, are you running the stock rear end? What backspace did you need to get those tires in there? (I'd like to do the same.)
yeah its a stock rear end but with a custom wheel, it looks flat ( as far as the off set goes) when you look at it. Its supposed to look like an american racing wheel. I think the wheel tubs were widend by the previous owner.
I am putting in a shorter rear end and using a off the shelf wheel, so i will be getting rid of these wheels soon.
