Had an oil leak at the front seal of the manifold, fixed it yesterday.
After removeing the manifold, I found that there is no rear water passage in it, but the heads have the holes in it.
It's 302 year 84, edelbrock performer alu heads and a edelbrock performer rpm manifold.
Cause I did't know about it, I was running it the last 1 1/2 year, without any probems!
What shall I do, what can happen?
Thanx in advance.
Martin
The heads have water passage holes in the rear because they are interchangable from side to side (you have to rotate them). The stock intake does not have a rear water passage.
You do not have a problem.
My old original 289 2 barrel intake has no rear water passage.
My Edelbrock RPM intake has a rear water passage.
My Victor JR intake has no rear water passage.
My later 302 EGR 2 barrel intake has a water passage.
Sheesh, I wish they would make up their minds, LOL.
I just pulled my RPM off my 289 yesterday to replace leaking gaskets. Same deal, no rear passages. But the rear is where the gasket blew. Too much pressure?
On intakes with no rear water passage I will paint the area around the port opening on the heads and also coat the intake manifold solid where the water port would have been and I also fill in that part of the intake gasket completely with red RTV. I haven't had a leak so far.
