1 - 13 of 13 Posts
I have an old article of one kicking around somewhere, I will try and find it.
They did go the way of the dinosaurs, Only made one or two years, and had problems with them, from what I've read.
Some of the HD moving trucks of the 70s and 80s used them. There is an art to speed shifting a moving truck with a 2 speed axle.
Just ask the guy in the caddy who lost a drag race to a moving truck.
Discussion Starter · #8 ·
well I did get some response about the
axle. Just about every auto maker of the
30's, 40's had a 2 speed rear axle available. Most notable is the Columbia
rear end, but I know there were other makes.
I always thought that it would be the
answer to some of the fuel economy that
we look for. You can have a tall gear for
drag racing, and a low gear for cruising.
Ford had a two speed axle option for there musclecars in 1969-1970.
It was used mostly on the Boss 302 and Boss 429 cars,but I have seen them in other models.
It was switched by a cable that ran up by the shifter or stick for the trans.
I ran some articals a while ago here that showed how they looked and worked,they are very rare units in any car.
1995 F-350 XLT SuperCab DRW 460 EFI 2x4~~1991 Mustang GT 5.0 5-speed
<font size=-1>[ This Message was edited by: DynoTom on 1/12/02 11:25pm ]</font>
Hey guyus, these things are still around, i see them about every day. the damn things weight about 200 lbs for the center section, though. mainly on L-8000 and L-9000 Fords, although there a few Internationals at work with them
You know, when you think about it, a gear vendors overdrive would offer the same fuel economy advantage that a two speed rear axle would.... I mean, a 3.73 rear gear effectivly becomes 2.83 with a gear vendors kicked on! I've never run one, so I don't know how well they work...
1 - 13 of 13 Posts
