Anything you can do, install or replace on a 302 works on a 289, and vis a versa.
The only exceptions are the early 5 bolt bellhousing blocks, the late model one piece rear main crank seal, lifter bore height for hydralic roller lifters and the sometimes disputed length difference in cylinder bore. Oh, yeah...make sure to match the water pump to the block and the application.
Keeping it simple...anything you can do to a 289, you can do on a 302; most of the things that you can do to 302, you can do to a 289 - with the exceptions noted above.
