I have a 66 289 engine I want to use for my 65 Mustang. The bores are 30 over, but the machine shop says they were not done well and they want to go to 40 over. Is that ok for this engine?
Second question. The crank journals are 20 over, but the rods are 30 over. The machine shop says this is bad, is that true? Is this crank junk?
Third question. Has any purchased an engine from PowerPro. They seem to be a large engine remanufacturing shop and they have offered an engine that is 30 over bore and 10 over on the crank. It seems to be a lot less expensive to buy a reman engine than let a machine shop loose to charge up the .......
I would appreciate all comments. In case you can't tell, I don't know what I'm doing.
