Hi,
I plan on building a 331 stroker based on a '72 standard bore Mexican block I recently bought.
The 331 is going into a street-only '67 Mustang fastback with C4, stock converter and stock 3.00 rear end, so it should have plenty of low end torque.
I was thinking about a Scat rotating assembly (cast crank, I-beams, forged pistons) and I already have an Edelbrock Performer RPM intake I can use, but could really use some help with cam and head selection.
What heads would you guys recommend for a mild 331 stroker, and what cam (needs to be flat tappet, solid or hydraulic).
TIA
<font size=-1>[ This Message was edited by: tminus3 on 4/27/06 3:49am ]</font>
TIA
