I don't believe there are any of us who have not been plagued with faded or crazed (small hairline cracks) tail light lenses. This project has the benefit of being relatively easy (2 wrenches out of 5 if you have some basic equipment). It adds a beautiful luster to the finished product, has UV Protection, and refurbishes your 30-40 year old, impossible to get, and ridiculously expensive lenses. Furthermore, following this method will give years of beauty to your lenses.
What you will need
• Air Compressor
• Paint gun, detail gun, or airbrush
• Automotive grade urethane clearcoat, activator, reducer, and fisheye reducer
• 800-1000 grit sandpaper
• Safety equipment for painting
Step 1
Remove the tail lights or headlights. This step is not 100%necessary. However, if you decide to paint with the lenses still on the car, understand that not all surfaces of the lenses will be refurbished. Also, you'll need to make sure that you mask the car very well or you WILL get overspray on your ride.
In the photos below you will see that I am refurbishing tail lights off an early model Opel that we customized into my sons car. These lenses were badly faded and crazed. Crazing occurs when the lens has been exposed to the sun, and over time they dry out and get small fractures in them.
Step 2
Thoroughly clean the lenses with a non greasy or waxy cleaner (don’t use furniture polish, oil soap, etc)
Step 3
Using 800 to 1000 grit sandpaper, sand the exterior (and if possible or necessary, the interior) of the lens. Most tail lights have a series of facets on the inside making sanding next to impossible. Once you have sanded to a satin finish, take a clean, lint free cloth, put a small amount of paint reducer or paint prep on the rag and thoroughly wipe down all surfaces on the lens. Use a tack rag to remove any lint or dust from the surface. <?xml:namespace prefix = o /><o></o>
<o></o>
Step 4
Following the paint directions, mix enough of the clear coat paint, activator, and reducer to complete the project, then add a few drops of the fisheye eliminator to eliminate any wax or fingerprints you missed.
If your lenses are badly faded you can visit your local body shop and ask the painter to tint some (not all) of your clear coat paint (before mixing) to approximate the color of the lenses.
If your lenses are crazed, start with the inside. Paint a relatively heavy coat of paint on the inside of the lens. Place the lens face down on a clean surface to allow the paint to penetrate any cracks and crevices in the interior of the lens. Wait until the lens is flash dry (15-20 min) and paint another lighter glossy coat. When this coat has flash dried, hang the lens from a wire hanger and paint the exterior of the lens. If the lens is crazed, paint a relatively heavy coat on the outside first (not heavy enough to run) and follow up with another coat as you did on the interior. Allow to dry thoroughly and reassemble. If you do happen to get a run in the clear, allow it to dry thoroughly, wet sand the run out, and repaint.
Note: If you are using a tinted clear on the lens, add an additional plain clear over the tinted coat.
If your lenses are severely crazed as mine were you may not remove all of the crazing, but it will be drastically reduced. As with every painted surface on your vehicle, the lenses will need to be waxed on occasion and if you have painted your headlight lenses make sure you get the bugs off in a timely manner just as you would your front bumper to keep the acid in the bugs from eating through your paint.
Here's a couple of pics of a finished lens.
That’s it! Pretty easy and the results are impressive. Most of all have fun keeping your old (or not so old) Ford on the road and looking good!
I bought and used a Megs heavy duty headlight restoration kit. At first it works really well, but the hazing came back after some months. In the end I just bought and replace it with a new tail light cover.
Most Mustangs suffer from floor pan rot. In some degree, our cars all suffer this. Like most of us, we want to do something about it, but neither have the time, tools or we DON’T think we have the ABILITY.
I can do many things, but floor pans seemed a challenge, and some of the articles...
I have wanted a soda blaster ever since I saw one demonstrated. Being on the tight budget that I am, I cannot afford the trailer mounted industrial unit that I saw demonstrated. For those of you not familiar, Soda blasting is similar to sand blasting but is used primarily for paint removal. It...
I wanted a hood scoop on the spare hood that I had for my 1965 Ranchero. I finally decided on a Shelby GT scoop. With detailed instructions from www.autobodystore.com forums written by Len Stuart, the owner of the site, I proceeded as follows.
Pictures read from left to right.
Picture 1
Take...
While I had my 67 Mustang stripped to bare metal, doing the body work, I decided to add the Shelby GT/Californial Special quarter caps and deck lid to my car. I always thought the California Specials were cool, always wanted one. I had an old school snorkel hood scoop on the car and in the 80s...
Several weeks ago I ordered a Eastwood Fender Lip Roller. I decided to spend the extra money and do it without cracking or chipping my paint. It bolts right onto your drum/rotor with your own lug nuts. I used a heat gun to soften the paint while we rolled the fenders. We started out rolling...
