Quick question here. I have e-brock RPM heads with ARP head bolts. I can't seem to get the head bolts off with a regular ratchet. Should I invest in a torque wrench? Will that make it easier? Any tricks of the trade in regards to removing head bolts?
Also can I reuse the ARP head bolts. They only have approx 1000 miles on them. Any help/info would be greatly appreciated. Thanks.
Banned
use a good, Craftsman, Proto, Snap-On, 6pt socket, 1/2 drive and a good breaker bar at least 18" long. Turn it in a counter-clockwise rotation. If you need extra reach use a very short extension and not a deep socket.
Never use a torque wrench as breaker bar. One of the few tools in my tool box that I do not think of as a 'multi-use' tool...unlike like a screwdriver which is not only good for screws; it makes a great pry bar, chisel, awl, weapon, solenoid tester, flywheel turner...the list is endless.
but a good torque wrench, especially digital, will easily lose calibration if you use them for breaking lose stubborn bolts.
tell the truth ...
, I've been just as guilty of doing the same, in a pinch.
Yes...you should have already had and used a torque wrench when you installed your heads.
Gorilla Arm calibration, where you yank on the bolts until they don't move, no mo' - is no way to install head bolts (or lug nuts on wheels)... How many times have you guys need dynamite to get lug nuts loose after a trip to the tire store? Seems some tire monkeys have a competition to see how high they can set the impact wrench. Then the next time you need to change a tire, in the cold rain, out of cell phone range, with regular tire iron - it will not budge.
First car tool to buy and keep in trunk ... a good 4-way tire tool is mandatory!
<font size=-1>[ This Message was edited by: Beoweolf on 12/9/06 9:52pm ]</font>
Any one else ever used a 4-way tire tool to remove head bolts? Crank dampner/Pulley bolt. Sometimes you get real creative, when you're a kid building your first engine and have limited tools.
A piece of pipe slid over the end of a breaker bar or ratchet will give you extra leverage for really stubborn bolts.. It may break a ratchet though so the breaker bar is best.
Thanks for the tips guys. I will try again today. I do have a cheap torque wrench that I could care less about, Could I simply just use the cheap torque wrench to get the bolts off? I really don't care about the wrench I can go buy a better one in the future. Thanks once again everyone.
Black65..,
The torque wrench measures and indicates when you have reached a given torque, it does not apply additional torque. Do you have a 1/2" drive "man size" socket set? PM me if you want to borrow mine. If you have lifetime warranteed tools, get a big bloody pipe, slide it over the socket handle like dacofa and frdnut says and pull away. Pull straight to avoid slipping and rounding off the bold head.
I once had a 460 (had a million miles on the thing) that I could NOT get 2 head bolts out. 600 lb-ft impact wouldn't budge them. 1/2 breaker bar and a cheater pipe resulted in a grenaded snap-on impact socket.
Old railroad turbo trick....heat the bolt up until it's almost red. Then take a water bottle and squirt the head of the bolt a few times, then back the bolt out. Works great on everything from stuck 460 head bolts to block galley plugs to turbocharger turbine bolts.
Breaker bar is best for removing head bolts. You might need a hollow pipe to slip over the end of the breaker bar for more leverage. I used part of my car jack handle to remove the bolts of my CJ engines heads. It works great if you're going at it alone.
