Got the pass side door skin, qtr patch and rocker on and probably worked to the 95% level. Going to let the body shop do the final finish and fit for painting.
Turned my attention to the "good side" of the car. Got it stripped and the door off for re skinning. I have the skin, came as a good deal set so may as well. There is not much rust, but what the heck?
The surprise was some more collision damage just behind the C scoop and along the top of the wheel radius. Looks like a parking lot crease, not bad, it was pulled out with a slide hammer and filled. Pretty nice work considering the age of paint on the car, probably 80s era.
I am thinking of cropping out the "buldge area" just behind the C scoop and along the wheel radius, buying the qtr patch and wheel radius panel and replacing them. The damage isnt nearly as bad as the pass side was, that is the only reason I am questioning if I should do this. At what point is filling minor damage better or time/cost beneficial over cutting an replacing. I may be too hung up on minimizing filler. This area had an 1/8th to 1/4 inch filler in some of the deeper areas.
Lots to be said for digging out old filler, it was starting to rust under the filler, so that would have ruined an expensive paint job in a matter of year.
I am off to DC for work for a few days, but will post some pics when I get back. Just wanted to toss this out.
Sorry so long, thanks Chris
